Nuther Coco back done..
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=9363
Page 1 of 2
Author:  LanceK [ Thu Nov 16, 2006 11:51 pm ]
Here is a coco back that I finished up last night. I got this set from Brock...Eh Brock see where those two knots fell, out of the pattern and somewhat under the braces. This is for a fella that both John How and I share as a customer...
Its on to the rosettes now...
Thanks for looking!
Author:  Dave White [ Fri Nov 17, 2006 12:06 am ]
Lance,
Immaculate and clean execution from you as usual. Lovely looking piece of wood to. It never ceases to amaze me how you keep the braces so clean with a wood like cocobolo
I didn't realise that you could get shares in customers - what will they think of next. You and John have been keeping that one close to your chests
Author:  Dave Anderson [ Fri Nov 17, 2006 12:25 am ]
Sweeeeet looking Coco back. That is so clean you could eat coco puffs off it     .....breakfast time .... very nice Lance
Author:  D Stewart [ Fri Nov 17, 2006 3:24 am ]
I love that coco. I am just so leary about working with it due to skin/respiratory issues. It's reputation scares me after having a reaction to pau ferro. It sure is pretty though, nice work.
Author:  Philip Perdue [ Fri Nov 17, 2006 3:30 am ]
Lance,
Very nice work! Does the back have a coat of finish on it or is that that the natural state of the wood?
Philip
Author:  Rod True [ Fri Nov 17, 2006 3:44 am ]
Very nice as usuall Lance. I sure like that
Author:  LanceK [ Fri Nov 17, 2006 3:45 am ]
No finish, just a wipe down of denatured alcohol to clean up the squeeze out. I use epoxy to glue braces to Cocobolo. Great tip I got from Brock..
Author:  Rod True [ Fri Nov 17, 2006 3:48 am ]
Lance, do you use the 24 hr cure of the quick set epoxy for this?
Author:  Rod True [ Fri Nov 17, 2006 3:49 am ]
Oh and do you use epoxy for the neck and tail blocks, basically anything that is glued to the coco? Or just the braces?
Author:  Brock Poling [ Fri Nov 17, 2006 3:52 am ]
[QUOTE=Rod True] Lance, do you use the 24 hr cure of the quick set epoxy for this?[/QUOTE]
West system 105 resin and 205 hardener.
Author:  Don Williams [ Fri Nov 17, 2006 3:52 am ]
Zzzzzzzz.....
Come on buddy! You can excite us more than that! Let's see some dust on the thing at least...
Don Williams39038.4955092593
Author:  old man [ Fri Nov 17, 2006 4:00 am ]
Very nice. Between you and Dr. Andy, I'm just about driven to try cocobolo
Author:  old man [ Fri Nov 17, 2006 4:01 am ]
Author:  Brock Poling [ Fri Nov 17, 2006 4:01 am ]
I call coco "poor mans brazilian" I love it.
Author:  Don Williams [ Fri Nov 17, 2006 4:06 am ]
Poor man's Brazilian....good one.
I think of Honduran Rosewood in those terms.
Author:  Andy Zimmerman [ Fri Nov 17, 2006 2:11 pm ]
I love Coco like Colin likes The Hog.
Author:  Rod True [ Fri Nov 17, 2006 2:19 pm ]
Just a bump for my question above.
Oh and do you use epoxy for the neck and tail blocks, basically anything that is glued to the coco? Or just the braces?Rod True39038.9306944444
Author:  LanceK [ Fri Nov 17, 2006 2:23 pm ]
Sorry Rod, miss that
Sofar just for the back braces.
I once had one brace pop off using LMI white and have been a little leary since, although I blame my self, I probably starved the joint.
LanceK39038.9335185185
Author:  Rod True [ Fri Nov 17, 2006 2:26 pm ]
Hey thanks Lance.
Can't wait to see more of your quiver. It's kind of full if I remember right
Author:  Serge Poirier [ Fri Nov 17, 2006 11:48 pm ]
You are just a bunch o' NEAT FREAKS!
Nice work Lance, i oughta go and spend time with you and Hesh and learn how to work cleanly like that!
Nice coco!
Author:  lee walker [ Mon Nov 20, 2006 12:35 pm ]
very nice work. I am also building a guitar with cocobola and i have had problems with bleeding stain under the finnish from the cocobola trim what type of finnish will you use and what type of prep will you do before you finnish Lee
Author:  LanceK [ Mon Nov 20, 2006 12:52 pm ]
Hi Lee, welcome to the OLF!
I use zpoxy for a sealer and catalyzed urethane for finish.
Author:  LanceK [ Mon Nov 20, 2006 1:55 pm ]
Terry,
I usually start by sealing the guitar with shellac while doing the bindings, rosette etc. After all the trim has been done, gap filling and final sanding I coat it with zpoxy which both pops the figure and seals the grain. After that I pack it up and send it off to Tony Ferguson. Tony's shots it and send it back.
I really want to give Addam Stark a try but I am to scared to send a guitar cross counry when Tony is just 2 hours away.
